Switching TEO-20 onto a TO-30?
Paul Kingsbury
02-08-2008 21:48:58
I have two tractors, a TO-30 with a good engine but it has problems with a Sherman transmission and axle. I have a TEO-20 that everything is good except the engine. I would like to merge the two; will the engine from the 30 directly bolt onto the transmission of my 20? I want to use everything from the transmission back from the 20, any recommendations?
Thanks, Paul in Oregon
ArleninOr
02-12-2008 11:27:18
 Re: Switching TEO-20 onto a TO-30? in reply to Paul Kingsbury, 02-08-2008 21:48:58
Paul, as to the swap go ahead and do it because they will work. Did one that way a few years ago with no problems. Don't think any linkage was different either. Any problems you can e-mail for my phone number as i live in Ore
Irv ( Ia)
02-10-2008 03:46:19
Don't know if it will work, but if you do make it work, I sure would be interested in the left over Sherman.
Irv*
Bob (Aust)
02-09-2008 02:48:28
Paul
I think may you need to clarify whether you have a TO20 (Continental engine, made in the USA) or a TE20 (Continental engine, made in the UK). There is not a "TEO20" Ferguson tractor.
I suspect the TE20 or TO20 probably will match to the TO30's Z129 Continental engine, but some of the guys on this forum from the USA should be able to confirm.
Bob in Oz
Paul Kingsbury
02-09-2008 18:10:10
 Re: Switching TEO-20 onto a TO-30? in reply to Bob (Aust), 02-09-2008 02:48:28
Ah,,, I see said the blind man...
I have a TE-20 and a TO-30.... My mistake. I want to bolt the 20's trans onto the 30's engine...
Does anyone know if this will work?
Thanks, Paul
Jeff-oh
02-11-2008 06:43:47
 Re: Switching TEO-20 onto a TO-30? in reply to Paul Kingsbury, 02-09-2008 18:10:10
The transmission cases have the same part number, which suggests they will inter change. I think I've heard and seen this done.
Jeff
