to 30 steering
craigreavley
02-08-2008 12:46:40
While blading snow the other night my steering become difficult to turn. I greased evrything I could, and filled the steering gear box with 90 wt oil. It was quite empty. Is there a way to grease the steering shaft from the steering wheel down to the gear box. it seems like the friction is coming from this area. A grease zerk would be convenient.
Bundee
02-08-2008 20:21:58
 Re: to 30 steering in reply to craigreavley, 02-08-2008 12:46:40
There is an upper and lower bearing ,they maybe your problem.
Jerry/MT
02-08-2008 14:03:17
These machines don"t have power steering so they are take some effort to steer unless you are moving slightly. The steering box uses the same type lube as the transhydraulic system and should be filled to the level of the gear centerline. Since it was empty, it"s possible to have some condensate form in the box and then freeze in the cold temps of winter. Try when the temps are above freezing and see if that makes a difference. If lubing it doen"t help you may have a damaged bearing in the steering box and it will need to be removed to repair it.
