Argh!! 1950 TO-20 Oil line rubber sleeve.
Bruce(OR)
01-27-2008 22:05:03
Playing with the oil supply line from the tube to the pump. On and off, twist it around and find myself looking at a chunk of rubber. Looks like an O-ring that came off the iside of the oil supply line. Unfortunately it is part of a larger seal that goes inside the nut at both ends of the inlet tube.
Got a part # 1 750 140 M1 from the parts manual.
Have searched various parts sources and no luck.
Thinking of using a section of rubber hose shoved in there to take the place of this item. Any ideas?
Brent, IN*
01-28-2008 16:06:59
 Re: Argh!! 1950 TO-20 Oil line rubber sleeve. in reply to Bruce(OR), 01-27-2008 22:05:03
Should be available from a Massey Dealer. I tried your part number and it now has 1064516m1 as the new part number. The description says "sleeve" and cost $6.68. Look it up at the link below. You can look up any Massey part on his data base. Toward the bottom of the home page you can click on Massey and type in your part number.
Bruce(OR)
01-28-2008 18:28:06
 Re: Argh!! 1950 TO-20 Oil line rubber sleeve. in reply to Brent, IN*, 01-28-2008 16:06:59
Thanks for the response! Still playing with it tonite in the 32 degree weather. Meant to check Jacks and spaced it. Talked to the local dealer tonite when I got home and the experienced parts guy had gone home for the night. This project is a real pain going together! And now the weather to slow me down some more. What fun!!
Bruce(OR)
01-29-2008 22:36:21
 Re: Argh!! 1950 TO-20 Oil line rubber sleeve. in reply to Bruce(OR), 01-28-2008 18:28:06
Went to the local hydraulics shop and poked around. Got two seals ordered and will be in tomorrow afternoon. About $3.00 against the dealers or Jacks $20.00 for the same part.
