gshadel
01-27-2008 06:31:28
Re: TO30 Questions in reply to MickF, 01-26-2008 15:46:54
Mick, check the oil level in your tranny using the side dipstick under your right foot, but chances are, what your seeing is leakage from the steering gearbox, not the tranny overflowing or whatever. If you think the gasket on the shifter plate is bad, just unbolt it, pull straight off, make a new gasket form gasket paper. Don't use that silicone stuff it ozzes everywhere & there are 2 driled holes with detent poppers/springs in the front that you don't want to goober-up with silicone. Then just drop the shifter right back on and tighten down. As for super-goop that stops oil leaks... don't know of any that don't do as much harm as good. You can shoot grease into your steering gearbox, or replace the seals in the gearbox... which is a pretty big job. As for the thermo, check again on the sides for an arrow, I've never seen one with no flow mark whatever. There are a couple different styles of thermos, but, if there is no mark, the end with the little plunger,seal, etc. should face towards the engine. On mine it is the "pointy" end of the thermo. If you get it wrong, you will now in about 10 minutes when your engine overheats.George
