Lift Fork Spring(s)
Hal Hadaller
01-15-2008 17:19:00
When taking apart my TO30 lift assembly, there where 2 springs anchoring the lift fork to the end of the lift piston assembly. My manuals show only 1 spring. Their are 3 holes in the lift fork that the springs hooks onto. Since I have 2 springs, the outer holes where utilized and presumeably the center hole would be used if only 1 spring per the manuals. Was there a modification over the years that recommended 2 springs in the TO30? If so, what was the problem?
Or did someone make a mistake in putting this unit together some years back>
Hal
Jeff-oh
01-16-2008 11:24:31
 Re: Lift Fork Spring(s) in reply to Hal Hadaller, 01-15-2008 17:19:00
I also only show 1 spring.
Dan S (NY)
01-16-2008 09:48:28
third party image
Here is a picture of the spring on my TO30. Only one was used. Someone may have been trying to compensate for a sticky control valve on yours by adding more spring force.
Dan
Jerry/MT
01-16-2008 11:35:23
 Re: Lift Fork Spring(s) in reply to Dan S (NY), 01-16-2008 09:48:28
Great picture, Dan! Thanks for posting it. You might want to put it in Parts and Pieces.
Dan S (NY)
01-16-2008 11:46:31
 Re: Lift Fork Spring(s) in reply to Jerry/MT, 01-16-2008 11:35:23
Thanks Jerry! Its in the gallery. I figured it might be usefull for reference for someone.
Jerry/MT
01-15-2008 21:43:50
My parts manual only shows one lift fork return spring. Where were the springs connected?
