schematics
ford-s
01-13-2008 13:50:43
could someone give me the electrical diagram,schematics for a '51 to-20.I need to find out if the wiring is correct.It has a wire coming from the starter,one to the battery,several going to the ignition switch,etc.,and the one closest to the starter is grounded,is this correct
Jeff-oh
01-14-2008 04:53:35
 Re: schematics in reply to ford-s, 01-13-2008 13:50:43
Ford-s
Did you get what you needed? or Are you still having trouble with the wiring Diagram?
I hope you fide the diagram to be pretty straight forward.
Bob (Aust)
01-14-2008 03:04:59
Ford
You must have looked at the first wiring diagram on the FENA wiring diagram list - it is for the Ferguson TEF20 diesel tractor.
HERE is the TO20 6 Volt wiring diagram. It is a pdf document so you will need to down load to your computer, then open with Adobe Acrobat.
Bob in Oz
Paul in AZ*
01-13-2008 20:23:42
If you have a TO-20, the sixth wiring diagram on the FENA list should give you the answers you need. It sounds like you were looking at the wrong diagram. There was never a diesel TO-20.
Richard L
01-13-2008 15:52:07
Did you try this page type in "to 20 wiring diagram"
in the "search for" spot? there was over 200 hits.
Richard L
01-13-2008 13:59:28
Try fergusonenthusiasts.com They will have everything you will need on their web page.
ford-s
01-13-2008 14:16:51
 Re: schematics in reply to Richard L, 01-13-2008 13:59:28
thanks Richard,but I've already been there,the schematic was vaque,and they did'nt have the gas conversion,just diesel,but thanks anyway,cw
