oil filter screen
John in MS
01-13-2008 10:48:15
I have been trying to round up oil system parts for my 1950 TO20, which were destroyed in an altercation with a ditch some years ago. Whoever did the repairs just did a rough patch job, and the tractor has been running without a filter for at least the last 10 years.
I have found everything except the oil screen that covers the filter element. Since the tractor is used only for light work these days, can I get by without the screen, or can anyone suggest a way to make something that will serve the purpose?
Thanks.
gshadel
01-13-2008 15:43:25
 Re: oil filter screen in reply to John in MS, 01-13-2008 10:48:15
John, it is worth noting that the stock oil screen strainer is a little taller than the filter. The reason being, the screen strainer pushes-up on the oil filter cover (that big steel can that should be inside your crankcase where your filter goes in), and holds the cover off the bottom of the crankcase. There is also a spring between the bearing cap, and the steel can oil filter cover that is gently pushing the oil filter cover down onto the strainer. If you have no strainer, your oil filter cover is just bouncing around in there, and I suppose under the right conditions, may settle to the bottom & contribute to starving the oil pump a bit.
My personal opinion is the strainer contributes more value than the filter itself. Only a small portion of your oil drains thru the center main bearing, and gets filtered, but all your supply oil to the pump is being strained thru the strainer, and the strainer prevents any debris from getting in your pump & causing damage. If all your oil filter components are missing, you will likely be just fine to fashion a small strainer out of screen, clamp it over your oil suction tube & change your oil with regularity, and be done with it. I'd recommend pulling out the steel can filter cover if your have no strainer in your crankcase.
The oil strainer screen is very simple design, just heavy screen material with a rolled metal bead around the top & bottom and open on both ends. You could probably make one pretty easy by just crimping some hardware cloth together in a cylinder shape and wrap some heavy screen around it, or using fairly fine perforated metal to make the sleeve.
George
John in MS
01-14-2008 13:38:39
 Re: oil filter screen in reply to gshadel, 01-13-2008 15:43:25
Geoge,
Thanks for the information. I do have that can, and was thinking along the same lines about fabricating something since I bought all the other parts already.
Funny how although there are so many replacement parts available for these tractors that it always seems to be the really rare ones that need to be replaced. Must be a law of nature... or at least farm machines.
John
gshadel
01-14-2008 14:23:22
 Re: oil filter screen in reply to John in MS, 01-14-2008 13:38:39
John, the spring that goes above the steel can filter cover can be bought for a few $$ at an Agco (Massey) dealer. If you don't already have one, get yourself a filter, and fashion a strainer that is... Ohhh, I don't know, maybe about an inch taller than the filter. I was thinking ~1/4" hardware cloth, that about any good hardware sells, is about the right looking stuff. Then wrap some window screen around that. Find some ingenious way to crimp aluminum, or lead, or thin steel around the top & bottom of the strainer to give you a more or less uniform edge. Who knows, you may make a nice repro. and be able to set-up your own web site selling replacement strainers for TO20's.
George
John in MS
01-15-2008 04:26:25
 Re: oil filter screen in reply to gshadel, 01-14-2008 14:23:22
George,
That sounds like a fun weekend project, so I'm going to give it a try and will send photos of the result.
I can't really tell from my manual, but does the outside oilpan cover push up on the filter element to keep it in place?
Thanks, again.
John
gshadel
01-16-2008 06:16:24
 Re: oil filter screen in reply to John in MS, 01-15-2008 04:26:25
John, That filter cover goes in with the open end facing down, towards the filter. That spring I mentioned goes above the cover between the cap & cover to push down on the cover, so the cover will push down on the oil screen to help keep it sitting on the bottom of the oil pan cover plate. Your filter is floating on the down tube inside the strainer because it is a little shorter than the oil strainer. The filter has a built-in gasket on each end to seal to the down tube to force the oil flow thru the filter and out into the crankcase.
Important note! - you have to install that filter cover before you install the oil pan, it doesn't go thru that bottom hole in your oil pan. So the cover stays in your crankcase all the time, only the strainer & filter drop out thru the oil pan cover plate.
First time I changed my oil, that cover was in upside down, I dropped the oil pan filter access plate and just saw a big piece of sheet metal, no filter or strainer.... couldn't figure out what was going on... I had to drop the oil pan to figure out what was going on in there.
George
