ONE WIRE ALTERNATOR.
klaus
01-13-2008 05:38:53
Just to let you know!
I purchased a one wire alternator, and fitted it to my TEA-20-80. But I kept reading that it could be difficult to get one of theese start chargeing because it needs higher revs to get it started. I came fitted with a 2,5 inch diameter pulley.But even if I just start the tractor at half throttle it starts to charge the battery instantly I can see on my ammeter.
So don't be put off if you are thinking og buying a one wire alternator.
Klaus.
marlowe
01-13-2008 12:10:15
 Re: ONE WIRE ALTERNATOR. in reply to klaus, 01-13-2008 05:38:53
the guys that say that don't know where to get the good ones. they will start as low as 500 rpm if they are made to
klaus
01-13-2008 11:58:34
Jd/Mo, I used this one. It is as simple as it gets:
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=60355346
Jd/Mo
01-13-2008 14:09:53
 Re: ONE WIRE ALTERNATOR. in reply to klaus, 01-13-2008 11:58:34
Thanks Klaus, I'll give it a try as soon as I get back to my tractor. My wireing has the batt. wire from the alt. going to the batt. connection on the starter switch. It's been working for 5 yeas that way, but maybe that's my problem. Thanks again.jd
Jd/Mo
01-13-2008 09:28:36
I've been haveing problems with my electrical system on a to-30, so I bought a new 1 wire alternator yesterday, NAPA guy said the old one was shot. Do you guy's have a wireing diagram for that alt.? I know it's a pretty simple instalation, I just want to make sure I get it right.
Thanks for the help
jd
Greg_Ky
01-13-2008 08:04:17
My one wire alternators start charging at 600 RPM.
