TO20 Front Rims
BrianJ
01-12-2008 12:20:19
I need to replace the front tires and don"t know the correct size. The tractor has Firestone G78-15 tires (it came that way) on the front, with a 5 hole bolt pattern. The rims I see for sale all have a 6 hole bolt pattern. Which is correct? What size rims and tires should be on the TO20? If I keep the existing 15" rims, what size tractor tire should I purchase (5.0-15 or 6.0-15)? Thanks!
Irv ( Ia)
01-13-2008 17:44:41
 Re: TO20 Front Rims in reply to BrianJ, 01-12-2008 12:20:19
I believe TO-20's came with 4.00 x 19 rims, but some folks put on 16" rims with a 5.50-16 inch tire. You have to be careful which rim you pick to make sure there is clearance between the inside of the tire and the the top of the spindle.
John (TR)
01-12-2008 20:27:52
Sounds like someone swapped the hubs and rims over to car parts. Tractor would have had 6 bolt hubs and 16" rims.
Hubs are on ebay from time to time and 8n Ford hubs will interchange. 16" Ag rims and tires are very common. Probably came with 5:50 -16
CENTAUR
01-12-2008 13:22:01
Go to MILLERTIRE.COM/ Another good detailed site is:carbibles.com/tyre-pg2html (CENTAUR)
