TO30 won't start
Rcimp
03-14-2001 05:57:34
My TO30 won't start, I hear a clicking coming from the solenoid so I suspect it is bad. The battery is fully charged. Can I purchase any Ford type solenoid to replace this one?
Jack Machin
03-14-2001 11:54:12
 Re: TO30 won't start in reply to Rcimp, 03-14-2001 05:57:34
The problem is definatly your solenoid. I have a TEF-20, and it did the same thing, it also wouldn't engage. I sent it to a fergie specialist, who had to put a new solenoid on, that was 2 years ago, and it still works.
I think what happens to the solenoid when it clicks, is that current is passed through the solenoid, causing it to create a circuit for the starter, but as the current passes through the solenoid, it, I think, shorts out, and goes back and forward, ceating a "clicking" sound.
Hope this is some help, get a new solenoid.
Jack
Phil
03-14-2001 06:42:47
Maybe you've done this, but first make sure your cables are the correct size and in good condition. Is your TO30 still 6 volt? That means larger cables than 12 volt system. Are the cable connections all good?
Rcimp
03-14-2001 07:02:12
 Re: Re: TO30 won't start in reply to Phil, 03-14-2001 06:42:47
I have 12V system, cables look good. It was working fine then just quit.
Ray,IN
03-16-2001 03:32:35
 Re: Re: Re: TO30 won't start in reply to Rcimp, 03-14-2001 07:02:12
Using jumper cables, try energizing the starter directly,bypassing the solineoid. If it runs, then it's got to be the solineoid.
Rcimp
03-19-2001 11:41:14
 Re: Re: Re: Re: TO30 won't start in reply to Ray,IN, 03-16-2001 03:32:35
Thanks for all the help, it turns out the starter is bad. It is currently being rebuilt.
Thank you all.
Rcimp
03-19-2001 11:35:43
Thank you all.
