Rear Tire Question
glenmorebuckman
01-02-2008 15:46:46
My To-30 is in need of a new set of rear tires and I have a few questions? The tires that are on it now are Goodyear 14.9x28's on 10 inch rims. I have a chance to buy two used tires of this size that are in really good shape, so I'm told, I haven't seen them personally. What I'm wondering is, with my old tires having most of the tread worn off and being such a tight fit to the fenders, will the new tires with more tread have clearance to fit. Also, I read somewhere that tire sizes changed, so are the old 14.9x28 sizes the same as a new 14.9x28. I was thinking about going to 12.4x28's but I can get a good deal on the 14.9's if there as good as they're supposed to be.
Higgi
01-15-2008 07:12:19
 Re: Rear Tire Question in reply to Kraeer, 01-02-2008 15:46:46
glenmorebuckman said: (quoted from post at 00:22:30 01/05/08) They're in Ky. Bob.
I have something totally different on the Rear of my TO-35 I have 14.9x24
they work and look great. The nice thing is they make a big foot print and stay on top of wet ground pretty well. This is my second set the first ones were full of fluid ! I didnt replace it with these and sorta regret it now
Paul Kingsbury
01-19-2008 19:35:47
 Re: Rear Tire Question in reply to Higgi, 01-15-2008 07:12:19
Hey Higgi
I"m wanting to put the same size tires on my TO-30!!!! But where can I find 24" centers and rims or the hole wheel to fit my tractor????? ???
Thanks, Paul
John (TR)
01-03-2008 18:15:41
 Re: Rear Tire Question in reply to glenmorebuckman, 01-02-2008 15:46:46
Your tractor your call but I would go 12.4-28.
Here's a couple of pix with an 11.2-28, 12.4-28, and a 13.6-28. As the tires get wider they get taller too. 14.8-28's wider and taller yet, a friend has a set on his TO35 and I think they look too big on that tractor.
third party image
third party image
Bob N.Y.
01-03-2008 16:33:11
What state are these tires in?
glenmorebuckman
01-04-2008 15:22:30
 Re: Rear Tire Question in reply to Bob N.Y., 01-03-2008 16:33:11
They're in Ky. Bob.
MattMalcome1
01-02-2008 17:30:24
That tire size is HUGE for a TO-30 and would not look right. I have found it is best to go with the correct size tire. Remember also, the wider the tire dimension with the same rim diameter, the taller the overall tire gets, affecting ground speed !!
Gerald J.
01-02-2008 16:04:22
14.9 are too wide for 10" rims. Look like donuts. 12.4 are the proper size.
Gerald J.
Don Hooks
01-02-2008 15:54:43
I can't answer the question about the 14.9 inch tires but I can't get my hand between my new 12.4's and the fender so you surely don't have much room to work. You could put some shims under the fenders to raise them enough as long as you didn't set the rims at their most narrow configuration.
