MF50 resurrection possibilities
Lyletx
01-02-2008 07:42:59
Hi Iam looking for advice. I have aquired a 63 MF 50 purchased the books and got home have $400 invested. It has not been ran for about 5 years bake tires good front tires bad hood and side panels need work. the reel question is the injection pump. it is a cav dpa3232178 ser.no 1917oc this seems to be the wrong pump. engin sn 2343713, inj nozzle holder no. BKBL67SD5151. the fuel system is a mess tank has been removed rusty inside lift pump is stiff secondary filter is missing primary filter element has been removed some fuel lines are attached incorectly. If I rig up fuel filters and an elcric pump to feed the injecter pump will the injecter pump work well enough to test the engin?
mark from the fort
01-02-2008 08:28:21
 Re: MF50 resurrection possibilities in reply to Lyletx, 01-02-2008 07:42:59
You should probably copy and paste your question on the other ferguson discussion site. The Massy Ferguson/Massy Harris tractors on that site deal with more of the MF models. Especially the models that are above the 20, 30, and 35 styles.
Your MF 50 is covered in better detail in the other ferguson site.
Take care, Mark
mark from the fort
01-02-2008 08:30:01
 Re: MF50 resurrection possibilities in reply to mark from the fort, 01-02-2008 08:28:21
I apologize, I wrote my response THEN checked out the other site. I very seldomly look at that site. I see you already sent your question over there as well.
My apologies. Mark
Lyletx
01-02-2008 08:36:57
 Re: MF50 resurrection possibilities in reply to mark from the fort, 01-02-2008 08:30:01
Thanks for your concern I did post it on the wron site the first time.
Lyle
