Jerry/MT
12-27-2007 19:53:57
Re: Engine Quits in reply to BuckTO30 NC, 12-27-2007 18:35:19
I agree with the other poster. When it quits check for a FAT, BLUISH-WHITE SPARK by pulling the high tensin lead out of the center of the distributor cap, hlding it near a good ground and trying a start. If you don"t have the requisite FAT, BLUISH-WHITE SPARK then you need to find out why. Bad connection, corroded, burned or dirty points, bad key switch, bad connections, shorted wire, etc If you have the required spark, then check for fuel flow by opening the tank valve, holding a suitable container under the carb, and removing the big plug on the bottom of the fuel bowl. The fuel should CONTINUOUSLY gush out like a cow peein" on a flat rock. If the flow i intermittent or just dribbles out, you may have some cloggeding in the fuel delivery system( fuel valve screen, sediment bowl screen or carb inlet screen) a kinked fuel line, a fuel bowl full of crud, or a bad float or clogged float valve.
