TE20 oil presure
Gary
03-11-2001 22:01:36
My TE20 has 50psi oil presure at start up drops to 0 when it warms up I have replaced the bigend bearings without improvement. It doesn't seem to get enough oil to the rocker valve train assy. hence the sticky valves. Iam starting to suspect a crack in the oil galery can anyone suggest a starting point to look for the problem.Cheers Gary
PETERC
03-12-2001 16:23:25
 Re: TE20 oil presure in reply to Gary, 03-11-2001 22:01:36
If you are not getting oil to the rockers it is likely that you are losing pressure in the cam bearings. your rockers get their oil from an oil passage coming from the cam bearing area.
