loaders
eagle35
12-25-2007 18:05:18
I just got my grandfathers tractor. Its a to-20 and I was wondering what kind of front end loader I could put on it. I found one but its off a ford 8n. Since I'm fairly new to it I thought I would ask. Thanks.
Kirk-NJ
12-26-2007 03:57:54
 Re: loaders in reply to eagle35, 12-25-2007 18:05:18
If you do buy the loader and have 4-19 tires/rims on your TO20 you might what to consider going with a 16 tires and rims like on the later TO's and 8n's. Like Phil said the steering is hard. Plus the 16's will handle the load better.
phil(va)
12-25-2007 19:49:40
The loader off an 8N should fit the TO-20, as the axles are about the same distance apart. If your loader has a front pulley, you will need the 'stinger' and adaptor for the front pulley on the tractor to make it work. These tractors with no power steering don't handle well with loaders installed, and loaders are not that easy to take on and off, so once you get it on probably you will be reluctant to remove it just to mow or plow. Just be aware of that, FYI.
DCollings
02-14-2008 19:22:26
 Re: loaders-stinger/adaptor in reply to phil(va), 12-25-2007 19:49:40
I am looking for information on where to get one of thost adaptors and stingers for the pump on a Wagner loader. I have a Furgeson TO-20 and a loader for a Ford 8N. Thanks
eagle35
12-25-2007 20:49:40
 Re: loaders in reply to phil(va), 12-25-2007 19:49:40
Thanks Phil(va) the loader does have everything.
