Not charging
John W. Mason,
12-24-2007 06:51:06
Battery is not charging. If the generator checks good I'll assume the voltage regulator is not working properly. I know nothing about adjusting the VR (if possible). It was replaced about 1 year ago when I rewired and changed to 12V. Any one have comments on the voltage regulators sold at TSC? Thanks for the input. Merry Christmas to all!
John
John Mason,Michigan
12-28-2007 15:32:33
 Not charging...resolved in reply to John W. Mason, Michigan, 12-24-2007 06:51:06
One of the brush springs was stuck. Back in buisiness. I am getting the 12V generator with the gearbox for the tractometer next week. Then I'll have a spare 12V genny on the shelf.
John
Bendee
12-25-2007 20:59:09
 Re: Not charging in reply to John W. Mason, Michigan, 12-24-2007 06:51:06
my red light stays on,a rev on throttle puts it out,so I agree with RoySC also found fan belt may appear tight but needs to be nipped up.correct belt helps.Never replaced a regulator.
Bendee
12-25-2007 21:26:35
 Re: Not charging in reply to Bendee, 12-25-2007 20:59:09
And on thinking about this, I used an alternator with an inbuilt regulator and remove the other regulator.
RoySC
12-24-2007 09:04:23
Had a similar problem...I came to the conclusion I wasn't running at a high enough RPM for the alternator to put out the correct voltage. I now throttle a bit higher....battery is charging.
Good luck.
Brent, IN*
12-24-2007 07:57:19
I have had the same problem. The voltage regulators I have purchased have usually lasted only a year. I polarize the generator before I start the tractor. Are they junk or is htere something else that might cause these to go bad so quickly? Anybody know?
iansb
12-24-2007 16:46:46
 Re: Not charging in reply to Brent, IN*, 12-24-2007 07:57:19
Hello,,,My voltage regulator doesn,t seem to be working either. Is there a way I could test the VR or would an automotive electrical shop be able to test it for me? Thanks Ian
