to-30 starts...sometime
Jd/Mo.
12-23-2007 09:11:30
1st Merry Christmas to all.
Ok, I tried to research the past articles, can't find help there, so I'm turning to the experts here on the board.
53 to-30, 12 volt conversion
new battery (2nd one)
new coil
new starter ( 2nd one)
new points and conderser
new ingnition switch
all connections cleaned tightened
When she's cold...fires 1st turn of the starter
When she warms up, sounds like a dead battery, charge the battery still get starter drag like dead battery, turn the key OFF and she turns over good, back on she drags. When she cools a little she turns over but no fire to no. 1 plug.
When she strats, runs for short time then just quits and wont re-start till way cold. When she starts cold she'll idle (kinda fast) for at least 1/2 hour ( on the last try) then does it all over again.
What am I missing? Help please! I 'need' my tractor. =)
Thanks in advance for any help you guys can give me.
JD
Bendee
12-25-2007 21:18:51
 Re: to-30 starts...sometime in reply to Jd/Mo., 12-23-2007 09:11:30
There is a similar post to this on Ford..starts when cold runs for half hour plus then cuts out.
suggestion was coil. Have you checked for cracks in distributor cap.? rotor button faulty?
Jd?mo
12-26-2007 07:06:45
 Re: to-30 starts...sometime in reply to Bendee, 12-25-2007 21:18:51
I have replaced the coil, and checked the dist cap. That seems to be ok, did get new points and condenser. still the same. jd
guyeli
12-24-2007 12:38:13
Been there,done that, feel your pain!!!
Basically had to replace everything including all wires.
Try :
(1)New starter switch
(2)Replace all wires,unless already done so.
(3)make sure points are gapped properly
(4)go thru the whole system w/a circuit tester and by process of elimination ascertain where problem isn't.
If you are able to find that your problem is related to inability to fire,then concentrate on your distibutor,wires ,or coil.Check the archives for how to overcome firing issues.
Jerry/MT
12-23-2007 15:50:24
I"d like to start at the igniton system. You say you got all new components on the ignition system and have a 12 V conversion. Do you have a real 12 V coil like NAPA IC-14SB(~$15) that does not need a current limiting resistor? Some so called "12V coils" require an external resistor to limit the coil current to 4 amps max or they overheat in about 30-60 minutes and you can"t restart til the coil cools off. Eventually, the the coil will fail from overheating.
When you changed to a 12V system, I presume you now use a 12V alternator which equires a negative ground.(The OEM system was 6V positive ground.) Did you wire the coil so that the small wire that goes to the distributor is on the negative terminal of the coil.
Make sure that you starter has a good ground. the battery negative ground should be attached to the back of the dash and should not be corroded or rusty. The contact of the starter with the block should be clean and not greasy or oily because that"s where the starter grounds.
You battery terminals should be clean(espcially since you have a new battery) and the cables should be 00 size without any corrosion in cable or where the cable enters the terminals. this will deliver maximum current to the starter.
When it starts and runs for awhile then stops, check the spark right away by pulling the center wire off the distributor cap and holding it near a good ground and trying a start. You should have a FAT, BLUISH-WHITE SPARK. If you don"t the problem is with the ignition system. If you do, check to make sure that the carb had fuel by opeing up the plug at the bottom and holding a containerunder it to catch the $3/gallon fuel. The fuel should gush out like a cow peein" on a flat rock. I fit doesn"t, if it just dribbles out, the fuel delivery system is restricted. If you have a timing light, you can easily check for what Gerald J. Is talking about by putting the timing light on and checking to see what the timing is. It should be 6oBTDC for rpms <400 rpm.
Systematically check these things out and try to start and run after you change anything to see if the change results in a fix. Then you"ll know what caused the problem.
JD/mo
12-24-2007 07:11:08
 Re: to-30 starts...sometime in reply to Jerry/MT, 12-23-2007 15:50:24
Thanks guys for the input.
Jerry, it is a 12 alternator, and The tractor has been running great for 5 years now. This problem has only happened in the last 3 or 4 weeks. It is a napa coil, got the number from this site, probaly from you. The - wire on the coil goes to the dist. and the starter mount as well as all the other electrical connections have been cleaned and tightened. New heavy duty batt. cables were re-cleaned with new batt. install. She's getting fuel ok, but I haven't checked the dist/coil wire to see if it's getting fire there yet. Trying that on return. I live in the city, and the tractor is in the country. Makes it hard to keep track of things here, but I do print out all the suggestions.
Gerald J. thanks for the input. After re-reading my fergie manual that does sound like a valid option and one that I'll try as soon as I get back. Jerry I've always gotten good info from you, so I'll re-check all of your suggestions as soon as possible. Hell it ain't like I couldn't miss something. Thanks agian guys, I appreciate your time.
JD
Jerry/MT
12-24-2007 14:11:34
 Re: to-30 starts...sometime in reply to JD/mo, 12-24-2007 07:11:08
Let us know what you find. Have a Merry Christmas!
Gerald J.
12-23-2007 16:47:02
That's SIX degrees Before, not 60.
Gerald J.
Jerry/MT
12-23-2007 19:16:02
 Re: to-30 starts...sometime in reply to Gerald J., 12-23-2007 16:47:02
6o= 6 degrees
Gerald J.
12-23-2007 11:07:25
Centrifugal advance in the distributor is sticking advanced. Makes it fire on the compression stroke and stalls the starter. Lubricate the felt in the center of the shaft under the distributor rotor and make sure that advance mechanism isn't stuck. The springs pull it back from advance while it sits and cools.
Gerald J.
