TE-20 Hydraulic Lift
Don
03-07-2001 17:21:59
My hydraulic lift has started to raise when any type of lifting pressure is applied. I.E., I can raise it by hand whether it is engaged or not. It will still lower or raise when I engage it but I think something is wrong. Any suggestions what could be causing this? Corrective action that can be taken?
Phil Myerscough
03-12-2001 11:32:02
 Re: TE-20 Hydraulic Lift in reply to Don, 03-07-2001 17:21:59
have you got too much oil in the hydraulic system?
Neal(IN)
03-08-2001 03:52:50
Don
It sounds as though everything is normal to me. The lift arms are connected by a shaft to a rod inside the cover. That rod sits against the back of the hydraulic piston but is not attached to it. So when you lift up on the arms you are not pulling the piston and so get no resistance.
Neal
Ray,IN
03-10-2001 19:03:39
 Re: Re: TE-20 Hydraulic Lift in reply to Neal(IN), 03-08-2001 03:52:50
Neal is right. The H. Ferguson tractors do not have any down pressure, only lift pressure. If you have the PTO engaged, and can lift on the arms manually to cause the lift to activate, the master control spring is not adjusted properly. With an implement on the tractor,raised, the spring should be snug, but loose enough to rotate by hand. Keep on tru- tractorin!
Phil Myerscough
03-12-2001 11:46:42
 Re: Re: Re: TE-20 Hydraulic Lift in reply to Ray,IN, 03-10-2001 19:03:39
yeh, they're right. My Ferguson does the same thing, but it's perfectly normal.
