TO 30 rod and main bearings
ctfarmer
12-08-2007 14:48:14
I just picked up a TO 30 basket case. The previous owner had started putting back together and lost interest. It has a newly ground crank and new bearings. Do the bearing caps go on with the tabs in the bearings facing towards or away from each other? My book is pretty vague in this matter.
Thanks in advance
Branlin
12-09-2007 08:04:15
 Re: TO 30 rod and main bearings in reply to ctfarmer, 12-08-2007 14:48:14
gshadel said: If your using a I&T service manual. it is well worth the extra ~$30 or so to get a re-print Ferguson service manual. That manual is literally 100 times more detailed than the I&T.
I bought my TO-20 in '77 and use it regularly, but I just recently found this site, and realize how much info is out there about my tractor that I didn't know.
Like the manual you speak of: where would I get one of these? third party image
Jim in OH
12-09-2007 10:25:16
 Re: TO 30 rod and main bearings in reply to Branlin, 12-09-2007 08:04:15
ditto George.. Opposite
gshadel
12-09-2007 07:35:08
ct..., I wouldn"t mind finding a basket case like that, sounds like the hard part, and large portion of the cost investment is already done. Putting together is the easy part.
It is typical to mark the bearing caps prior to removal with punch or chisel marks so they can be re-assembled in the original orientation. Take a real close look at your parts to see if that might be the case. According to the service manual, "the notches for the tongues of the bearing liners must be on opposite sides of the shaft." If your using a I&T service manual. it is well worth the extra ~$30 or so to get a re-print Ferguson service manual. That manual is literally 100 times more detailed than the I&T.
George
