guages
Dan from bright
12-07-2007 14:46:16
hi , ihave a tea 2085 1953 and i have 1 guage for the oil pressure and the other is not there , i would like to know what it should be.
GertM
01-02-2008 00:10:53
 Re: gauges in reply to Dan from brighton, 12-07-2007 14:46:16
third party image
If you are from Brighton,England it's easy.
To Install a white face original gauge you can order these originals in Europe with Arno van Dokkum or ArvanDo Oldtimer Gauges.
Put his name on google,he sends througout Europe but also to New Zealand I heard from him.Better than the cheap made in China gauges I got from my Ferguson supplier.E-mail:
See www.annatefka.com
Gert (Switzerland EU)
John Mason, Michigan
12-12-2007 06:27:38
 Re: guages in reply to Dan from brighton, 12-07-2007 14:46:16
Dan, Are you from Brighton Michigan?
John
Bob (Aust)
12-07-2007 16:02:14
I too have a 1953 TEA20, Ser No TEA341439.
The TEA2085 came standard with a white faced oil pressure gauge and red ignition/generator warning light.
The second gauge hole had a blanking cap installed ex factory.
If you wish to fill the hole, install a water temperature gauge, available from most Fergy parts suppliers. I have been unable to find a matching white face gauge. The temperature probe installs in an existing threaded hole in the left side of the thermostat housing, below the top radiator hose.
DennisPinOhio
12-09-2007 06:10:58
 Re: guages in reply to Bob (Aust), 12-07-2007 16:02:14
If you look in the Summit Racing Catalogue or go on line, I believe they have "period" gauges with white faces. They may not be a perfect match, but will look appropriate.
Jeff-oh
12-08-2007 04:48:34
The other was most likely an amp-meter. However, a water temp gauge is more useful to the user.
Iansb
12-07-2007 17:57:49
Hello,,,,,I have the same tractor,,,,the other gauge is water tempurature.
