What is the lever for on a TO-30
craigreavley
12-07-2007 12:32:55
Ok all you experts I am restoring my fiirst TO-30. What is the lever on the left side of the steering wheel for. It is below the dash, and is some sort of lever that must have done something. Mine has nothing attatched to it. Also where can you get a repo steering wheel. The ones on Ebay have bare metal on the spokes. Do they make an original wheel that the spokes are covered with the steering wheel material?????
Paul in Ms
12-10-2007 04:41:09
 Re: What is the lever for on a TO-30 in reply to craigreavley, 12-07-2007 12:32:55
There is one on Ebay #200182407453
TexMac
12-09-2007 21:54:51
My original wheel has bare spokes.
Jeff-oh
12-08-2007 04:53:17
I believe the orgional steering wheel did not have any covering on the spokes. But I have TE's. The parts book does suggest the steering wheel spokes do have a covering.
John (UK)
12-10-2007 11:23:54
 Re: What is the lever for on a TO-30 in reply to Jeff-oh, 12-08-2007 04:53:17
The original wheels had no covering on the spokes.for a number of years, later ones did have right up to the end.
phil(WA)
12-07-2007 15:55:37
The lever is supposed to be attached to a rod assy that extends from one side of the dash to the other and has hooks at each end of the rod which when actuated by the lever will engage brackets in the hood and then hold down the hood. Your parts book shows this clearly if you have one.
Phil (WA)*
Dan S (NY)
12-07-2007 12:36:57
If the lever is attached to the underside of the dash it is most likely the hood release lever.
Here is a link to this sites steering parts...
Dan
