corey farnswort
12-05-2007 18:07:05
ok, so not so long ago you fine folk helped me resolve my "it runs for 20 min then dies problem", after much troubleshooting i found it was a break in the cloth covered aluminum wiring. Once i rewired it she ran beautifully. now that its cold out however, and need her for plowing the driveway, she wont start at all. here are a few details to the problem: Even though these tractors were originally a pos. earth system, I wired mine neg. earth which is what it was when i bought it and has run for over 100 hrs on. 2)it was converted from the shift activated starter switch to a basic 12 volt solenoid before I got it but once again ran for many hrs with it like it is. 3)Ive replaced all wires,plugs, rotor, cap, generator, control box, on/off switch(last fall), starter and solenoid(2yrs ago),new battery 2 days ago. Here are the symtoms: sometimes all i get is a clicking noise in the solenoid when i push the start button, other times she'll turn over but its very strained and never enough to fire her up (yes, i step on the clutch to dissengage all of that cold oil filled gearing). Another semi unrelated problem I'm having is my carb. She came with a zenith b-16, b-18 or a b-13 (not sure due to worn numbers) and has run with it, had it rebuilt by a mechanic because it was leaking out of the choke area, and now is leaking again. the leak would go away once it ran but had to turn the gas off when not running to avoid the flooding problem. I know she really requires a zenith z4t2 or replica but dont want to replace it unless I have to. any help with this is much appreciated, my little quad is taking a beating clearing my 200 yard drive way...
