to20 or to30??
David McChesney
12-05-2007 11:16:23
not sure what model, here some info, I found, on the stering rod, found HF TO3130, motor number is Z129340835, will this help any, any response would be great, btw, what hp are these guys
Jim.UT
12-07-2007 10:17:34
 Re: to20 or to30?? in reply to David McChesney, 12-05-2007 11:16:23
Jim in OH did a study that showed the correlation between engine numbers and serial numbers on TO-30 tractors. Basically if you take the engine number and subtract 240,000 from it you get a pretty close approximation of the serial number of the tractor.
The tractor serial number was stamped on a tag riveted to the dash above the steering column. I assume your s/n tag is missing. However, given the engine number you have, your tractor serial number would have been in the neighborhood of 100800. You can look in the serial number chart to find the year.
Jeff-oh
12-05-2007 13:40:45
What John Said.
Z120 is a TO-20 engine
Z129 is a TO-30 engine
it is the engine dispalcement BTW. 120" or 129"
John (UK)
12-05-2007 11:44:23
With a Z129 engine it is a TO30. 30.27hp
