TO-20 transmission fluid is milky.
Docshaffco
03-05-2001 17:14:07
I replace the transmission fluid last fall. Did a lot of snow plowing this winter, and now it's appears milky white on the dip stick. Any ideas as to what causes this? Should I change it again?
rod
03-05-2001 17:33:22
 Re: TO-20 transmission fluid is milky. in reply to Docshaffco, 03-05-2001 17:14:07
water in oil caused by condensation and leaks around housings and shifter lever especially if left outside in rain. There is a lot of surface area in the housings for condensation sometimes if the tractor sits for a few weeks you can just crack the drain plug and get some water out that way otherwise change it for new.
regards
rod
