Engine Overhaul Parts.
Hal Hadaller
11-27-2007 15:50:35
In the process of overhauling my Z129 engine, I have gone on a major time consuming search for parts and pricing. I discovered one very reliable site in Peurto Rico. Example is Rings for $29 complete engine, complete gasket Overhaul Set with ALL gaskets (including crankshaft seals) that one needs for a major overhaul for $34. All parts are Clevite or Sealed Power but in older looking boxes. I even got my 0.003" oversize piston pins from them and main bearing set. www.mecanicapedrosa.com If there are any problems, they do not hesitate to email promtly. Also cheap on freight for me in Florida. I will be having some gaskets to sell that I already have purchased before finding this deal.
Regarding my overhaul, it has turned into a MAJOR but am at the point that I can start putting things back together using a BRAND NEW $275 crankshaft. I did have one major problem with the block and that was a crack thru the centor main bearing jounal face. Local sources say that cross-boltinging the case is a common fix and works, which I have now done. My crack was minimal but was there right thru the oil galley which could lead to oil pressure problems.
I finally got the rocker bushing out of the rear end housing. I did not have a puller but did find, in one of my tool boxes, a bearing puller that I rigged up to PUSH. After some leverage and a few very loud POPS, it started moving and was able to finish the push with a wheel air wrench. So this finished all my problems in removing things. What a relief. Having the right tools makes a hard job easy, which is the major problem for many of us.
The only problem now is finding all the removed pieces that are scattered about my shop. Just about a whole tractor of removed parts. I am sure that I will have to use the manuals for some of the re-assembly. Cleaning is also a major headache. I know that I have purchased more than $1,500 of parts and maybe as high as $2,000. And that is doing lots of internet shopping for the best prices and freight charges combining shippments. I still need new tires for the rear and more than likely some minor brake parts. And, not to be bragging, but in the brief time on the Ferguson, I have become somewhat of an expert with advice from folks here on this website, my manuals, and elsewhere, coupled with my mechanical background.
Hal
Crem
11-28-2007 20:05:47
 Re: Engine Overhaul Parts. in reply to Hal Hadaller, 11-27-2007 15:50:35
I can hear you on spending money for parts for getting the Fergy going. Once it is finished though you will have a nice machine. If you have a use for it you will find that it is very good for mowing, landscaping and a lot of other odd jobs. I have a MF 165 diesel, but I can work circles around that for the type of things that I do. In fact I almost hate to climb up on that thing. Of course if you need pulling power than that is the one to use.
Where did you get your crankshaft?
Hal Hadaller
11-28-2007 21:04:01
 Re: Engine Overhaul Parts. in reply to Crem, 11-28-2007 20:05:47
I got my crankshaft from THE Company
Link
I called them about the rebuilt crank for $286 in their listing. But he said they get them from another supplier in Iowa. He then asked me what is wrong with a new crank. I said price and he said you would be surprised. They have the new in stock so rather sell those. 2 days later I had my NEW crankshaft for $290 including shipping to Florida.
