REAR AXLE
Donald Daughert
11-26-2007 05:26:29
Anyone know where I can find a rear axle for a TE 20. Serial No. TE33835. The axle has 16 splines. Thanks Donald
John (UK)
11-27-2007 08:22:27
 Re: REAR AXLE in reply to Donald Daugherty 1, 11-26-2007 05:26:29
That rear axle on your tractor is NOT the original one, it has been changed if it has only 16 splines on the axle shafts. They fitted a heaver duty axle to them with 19 splines at serial 325,001. These axle assy. will interchange if you can find a later type. From the back end of the gearbox (just forward of the seat) you can change the whole thing. They are much stronger axle-shafts and bigger diff assy, hydraulics are the same....John
