temp.gauge?
ford-s
11-23-2007 06:11:25
I just bought a 1950 to-20,to be restored,I am like a kid in a toy store.My projects so far have been with fords,fordsons,and olivers,this is my 1st ferguson.1 of my problems is that I want to hook up a temp.gauge,there is an ammeter,and an oil pressure gauge,but I can't find a place on the motor to hook up a temp.gauge,am I overlooking something.I am enjoying the pages Ihave been reading,and hope that I will be able to join the'fergie family'thanks a lot,cw
Alex MacEwing
11-24-2007 06:37:28
 Re: temp.gauge? in reply to ford-s, 11-23-2007 06:11:25
I installed one in my 1951 TEA 20, in the spot they are referring to at the top of the water pump. I used an item # A-50A25 from A & I Products.....Thks Alex...
Jerry/MT
11-23-2007 10:20:10
If you look on the "gooseneck" that comes off the cylinder head and is connected to the radiator via a hose, you"ll see a boss with a plug in it. That"s where the temperature sensing bulb for the temp gauge goes.
ford-s
11-23-2007 16:47:00
 Re: temp.gauge? in reply to Jerry/MT, 11-23-2007 10:20:10
thanks jerry/mt I checked and it was right where you said it would be.thanks again,cw
JerryCPP(WA)
11-23-2007 10:18:29
Look on the left side of the water outlet on the front of the head. That's where my '49 TO-20 has its temp gauge hole. If you see an old part of the sending tube sticking out, all you need is a new gauge. If it's a pipe plug, you'll need the pipe thread to special nut adaptor too. You can get these at a NAPA store if the one that comes with the new gauge isn't the right size.
Ken Crisman
11-23-2007 09:23:10
Is there no plug in side of the head at all ? Surely the manufacturer put one for cleaning & draining purposes . If not , I see on ebay a temp guage set up that goes into one of radiator hoses & the guage mounts in the dash . I saw it in the Ford section so I"m not sure if it"s also in the Frgy section . Check it out . Good luck & God bless, Ken
