TO 30 OIL FILTER ?
MIKE GARLAND
03-04-2001 09:56:29
IS THE OIL FILTER IN THE PAN ON THIS TRACTOR , MY DAD JUST GOT ONE AND WE CAN'T FIND THE FILTER . LOOKS LIKE THERE USED TO BE A OPENING ON THE PAN BUT IT HAS BEEN WELDED UP. IF IT GOES IN THE PAN ANY THOUGHTS ON WHERE TO GET ANOTHER PAN . THANKS MIKE
Duner Wi
03-05-2001 09:37:14
 Re: TO 30 OIL FILTER ? in reply to MIKE GARLAND , 03-04-2001 09:56:29
Per chance you have a TO30 with a TO 20 engine then it is possible to have the oil filter access welded shut. The access to the oil filter is about 7 inches in dia.on the bottom most of the oil pan.Would have a bolt in the middle with an oil dran plug just to the side. I have seen this done in the past. If it is a TO 20 engine it should have a Z120 cast into the block on the left side if I remember correctly.
Ray,In
03-04-2001 16:42:32
The oil filter is located on the right side of the engine block below the carb. The canister type filter is mounted horizontally, so have a drain pan underneath. Unscrew the bolt and remove the canister. The filter is inside. Remove the old sealing gasket from the engine side, as a new one is included with the new filter. A new filter is available from NAPA or Carquest auto supply stores. A MF dealer will have them too. While you are at the MF store, you will appreciate buying a owners manual for your tractor. This booklet contains all the needed information to make adjustments and maintain it. MF prints replicas of the orginal, so all the instructions are accurate.
Ray,In
03-04-2001 16:40:49
The oil filter is located on the right side of the engine block below the carb. The canister type filter is mounted horizontally, so have a drain pan underneath. Unscrew the bolt and remove to canister. The filter is inside. Remove the old sealing gasket from the engine side, as a new one is included with the new filter. A new filter is available from NAPA or Carquest auto supply stores. A MF dealer will have them too. While you are at the MF store, you will appreciate buying a owners manual for your tractor. This booklet contains all the needed information to make adjustments and maintain it. MF prints replicas of the orginal, so all the instructions are accurate.
