Do ou think this will fit my to35
John (TR)
11-10-2007 20:19:26
I know its off of a Ford but the canisters are nearly identical.
phil(va)
11-13-2007 11:23:26
 Re: Do ou think this will fit my to35 in reply to John (TR), 11-10-2007 20:19:26
I have one on my F40, and another one on my NAA Ford, but for the life of me I can"t remember for certain if they are the same. I don"t think so. I think the oil circulation holes are different, and not sure about the mounting bolt. The one I got is available thru Sparex (thru a Sparex dealer only). The Sparex catalog says it fits a 30 as well as a 35, but of course it does not fit a 30. However, it did work just fine on my 40 (same engine as 35).
Jerry/MT
11-11-2007 16:05:30
Only one way to find out, John. Give it a try. You can always revert back to the original system if it doesn"t. I bought one off this sight (@ ~$29 plus shipping with a filter it is overpriced I might add)and the sealing gasket did not fit. I think it came from the "land of almost right". I ended up making a gasket out of thick gasket paper and it works fine. It"s a lot easier to do a filter change now.
John (TR)
11-11-2007 17:45:41
 Re: Do ou think this will fit my to35 in reply to Jerry/MT, 11-11-2007 16:05:30
I'll post back. I have a 641 motor with one on it and was just avoiding taking the canister off the TO35 unnecessarily
135 Fan
11-10-2007 21:10:23
Depends on what engine you have. An MF dealer might have just the adaptor you need. I got one for under $20 for my 3 cyl. Perkins. Dave
