tire pressure
DanB
11-10-2007 15:09:45
what is the tire pressure for front & rear on my Harry Ferguson??....the rears do have chloride.
phil(va)
11-10-2007 20:23:22
 Re: tire pressure in reply to DanB, 11-10-2007 15:09:45
I run 30 in front and 14 in rears (with fluid).
motorv8N
11-10-2007 15:40:43
My 51 TEA 20 came with a photocopy of a 1952 manual. In it they say the following about tire pressure:
FRONT
4.00-19.....26 lbs
6.00-19.....26 lbs
REAR
10-28..... ..12 lbs
11-28..... ..12 lbs
Interestingly, no mention of loading tires at all anywhere in the manual. Also, I don't know if "modern" tractor tires would require different inflation.
John(UK)
11-11-2007 11:32:32
 Re: tire pressure in reply to motorv8N, 11-10-2007 15:40:43
If you use a loader you inflate the tyres to 30psi on th front.
The rear tyres at 12psi is ok under normal conditions but if it gets wet or sticky going drop the tyre pressures to 10psi so that it will flatten out slightly and give more grip...John
DanB
11-10-2007 18:41:10
sounds good to me ..... my manuel covers EVERYTHING but tires & pressure ..... ..thanks , Dan
