Another bonehead move
Archie in KY
11-10-2007 13:11:54
Fellows: I am replacing the power steering hoses on my 57 TO-35. Unfortunately I took both hoses off at once and did not mark the fittings for re-installation. My manual identifies the lower hose on the pump as the high pressure and the upper as return but I can find no indication as to which fittings they go to on the steering column. I thought about just hooking them up and changing them if it didn't work but thought better of it as I don't want to blow a seal or something worse. Could someone with a similar tractor take a look and tell me if the high pressure fitting is the one closest to the engine or the drivers seat.
RegoR
11-14-2007 06:33:54
 Re: Another bonehead move in reply to Jerry/MT, 11-10-2007 13:11:54
Hi Archie,
Do you still need info on this?
If so, let me know and I'll have a look at my '57.
Roger
archie cope
11-15-2007 16:09:40
 Re: Another bonehead move in reply to RegoR, 11-14-2007 06:33:54
Thanks for the offer Roger but one of the other fellow sent me a photo so I'am squared away now. This is one great list for vintage ferguson guys
135 Fan
11-10-2007 21:16:49
 Re: Another bonehead move in reply to Archie in KY, 11-10-2007 13:11:54
Can you tell by the lengths of the hoses? If the hoses are rated for differnt pressures, the higher pressure hose should be stiffer and possibly a little smaller inside diameter. It's also posible both hoses are the same. Try bending the hoses in a tight loop. If one wants to kink it's not a higher pressure hose. Hope this helps. Dave
Archie in KY
11-11-2007 17:19:49
 Re: Another bonehead move in reply to 135 Fan, 11-10-2007 21:16:49
I had the hoses made up at napa, they are the same length and pressure rating. The problem I am having is figuring out which fitting on the steering column is the hi pressure and which is the return
Berryville
11-10-2007 13:33:56
 Re: Another bonehead move in reply to Melville Will, 11-10-2007 13:11:54
Sounds like something I would do.... ummmm..... have done.... Friends laugh at me because before I disassemble anything I take photos if whatever I'm working on with my digital camera. I can always go back and look at the photo on my computer, zoom in or out or even print the photo to take out to the garage with me.
Wish I could help but mine is a TE-20 and has no power anything...
Pete,
"49" TE-20
