TO-20 front axle piot pin
Keith-IN(US)
11-09-2007 10:01:26
I am thinking that I need to replace the pivot pin and bushing on my To-20.. How hard of job is this and is there anywhere I can find a write up about how to get this job done??
Thanks
John(UK)
11-09-2007 10:40:10
 Re: TO-20 front axle piot pin in reply to Keith-IN(US), 11-09-2007 10:01:26
Remove the Hood, remove the Radiator then you wont damage it and store it safely. remove the bolt/nut that holds the pin in position, put a jack under the Clutch housing to take the weight off the axle and then using a pry bar, lever the old pin out. You will need to replace the bush in the axle as well and it may be worn right through and be wearing the axle beam, depending on how bad it is you can remove it from the tractor and have it built up and machined or get a new centre beam...John
