economical 12 volt conversion- TO-30
GUYELI
10-28-2007 13:33:29
Looking to change over to 12 volt on my TO - 30.Wanted to find an economical method to achieve this.What type of alternator would be appropriate? Where can I get the mounting brackets without having to buy a conversion kit for $$$$.Any suggestions would be welcome.
Lance J.
10-29-2007 08:41:51
 Re: economical 12 volt conversion- TO-30 in reply to GUYELI, 10-28-2007 13:33:29
I installed a Delco one wire unit from O'Reilly's on my '55 TO-35. Just bolt it up, hook up your battery charge wire and go. I paid seventy bucks for mine after turning in a junk alternator for core. The top bracket you have now may or may not fit. Replacement universal top brackets are available at auto parts stores and hot rod parts websites for a reasonable price. The only caveats about my setup are: A.- After starting the tractor, rev the engine to around half throttle to get the alternator charging, as indicated by a positve amp reading on the dash gauge. After it has started charging it will do so at any engine speed until the tractor is shut off.
B.- Installing this set up will cause you to lose the use of the cable driven factory tachometer. There is no way that I am aware of that the original tach can be made to work with an alternator.
If you have any questions, don't hasitate to send me a message.
dfitch
10-29-2007 05:10:25
when I converted my TO-30 I bought an alternator for a 1978 Camero 350 with air from AutoZone about $40 plus a $20 core charge. I modified and reused the generator mounting bracket to mount the alternator. I took a series of pictures and can send them to you if you want. I also used the belt pulley from the generator on the alternator. I think I had to put a spacer behind it to keep it from compressing the cooling fan on the alternator. If you want more info my email is ddfitch at htc dot net
Doug
Jerry/MT
10-28-2007 16:52:13
Most people get Delco 10Si alternators that have an internal regulator built in. They were used on GM cars for about 10 or 20 years and you can find them in wrecking yards pretty cheap. You"ll also need a pulley for the wider belt on the TO-30(I think it"s a 5/8" belt).If you don"t buy a ready made bracket you"ll have to make your own.
My -30 had been converted before I bought it. I"m sure that someone who has done the conversion can give you more info.
