TO-30 parts
Matt Malcome1
10-27-2007 17:47:58
I have two TO-30 tractors for parts. Both have cracked blocks top and bottom between cylinders. Sorry, I like the Fords better. Ouch. I will sell cheap and ship freight if I necessary. I don"t get any response from this forum on much of anything..hard to believe someone dosen"t need something..... ...Thanks for looking.
Lance J.
10-29-2007 08:47:12
 Re: TO-30 parts in reply to Matt Malcome1, 10-27-2007 17:47:58
Matt, have you tried posting an ad in the "classified ads" section in the left topmost column of this screen? I think the ads are free, and you might find interested parties who don't come to this forum.
Matt Malcome1
10-29-2007 14:55:40
 Re: TO-30 parts in reply to Lance J., 10-29-2007 08:47:12
Yes, I already placed ads for all of the most desirable parts in the Classifieds, but I want the most exposure. I am still learning how to use this forum, so any advice is appreciated. Thanks!
Matt Malcome1
10-29-2007 04:29:45
Also I wanted to add, I agree Harry was the genius behind the success of the Ford tractor, and I do have a running TO-20 with the sherman "live PTO" conversion. Still, the Ford is an excellent tractor, with the Ferguson being it's equal in my opinion. I guess maybe between the three Ford N's, and the three Ferguson's, I have three running Fords, and only one running Fergusons....(if the blocks were not cracked, I would restore one of the TO-30's..not too many cracked flathead fords :-)
Richard L
12-02-2007 10:46:10
 Re: TO-30 parts MATT MALCOME in reply to Matt Malcome1, 10-29-2007 04:29:45
Matt is either of the TO 30's for sale? Where are you located? (Probably to far away.) Thanks Richard
Matt Malcome1
10-29-2007 04:22:29
I am located near Metamora, IL, about 20 miles east of Peoria, route 116. I do not have pictures yet, my wife on vacation with the camera, but I do have double internal engine parts with only one good crankshaft and cam. I would LOVE to sell everything as a package deal, it is a shame to leave it outside. I can tell you the sheetmetal is near perfect--no torched holes, just a few minor dents and one set perfect fenders. These tractors are split, but can be reassembled for easier loading and transport. Thanks for the replies.
John H TO20
10-29-2007 06:35:17
 Re: TO-30 parts in reply to Matt Malcome1, 10-29-2007 04:22:29
I need a left side individual wheel brake arm if you are willing to sell one seperately.
Matt Malcome1
11-02-2007 16:33:23
 Re: TO-30 parts in reply to John H TO20, 10-29-2007 06:35:17
Do you still need the left wheel brake arm John? I replied on the forum, but haven"t heard from you. It dosen"t show you have e-mail, so my number is 309-367-2837 if you need to call. Thanks. Anyone else reading this and needing parts, please call evenings and weekends only. Thanks and have a good day.
Matt Malcome1
10-29-2007 14:52:35
Ok, do you need the actual pedal or the arm that is between the back plate and the tractor body? Either way, a check for $25.00 will cover the part and shipping. Send check to 916 County Road 1800N, Cazenovia, Il 61545.
ericlb
10-28-2007 19:41:58
im pretty sure im going to need some engine internals [ if mine isnt cracked too] but i havent had time to tear into it yet, i bought a to 3o from a old guy who just wanted it gone it had sat under a shed for 10 years and "has a knock in it] now it also has junk tires too, but it was very cheap so i can hopefully build it back up soon, where are you?
Matt Malcome1
10-29-2007 14:46:47
 Re: TO-30 parts in reply to ericlb, 10-28-2007 19:41:58
Please see my broad response to "where are you?" I am just now figuring out how to use this forum. I have a complete gasket set and sleeve o-rings and piston rings for the 3 3/8 inch pistons all brand new. One of the 3 3/8 sleeves has a chip out of it at the bottom past the o-ring area about the size of a dime.. other than that, they can be re-used after new piston pin bushings are fitted. I bought a tractor with a "knock" in it, and found the oil pump gear was spinning on it's shaft, hence no oil pressure. The guy ran it until the crank journal #2 was blue and beyond machining. Some people....
Hal Hadaller
11-07-2007 07:33:35
 Re: TO-30 parts in reply to Matt Malcome1, 10-29-2007 14:46:47
For Matt - you say you have some pistons or cylinder parts you don't need? Reply to flyhal@yahoo.com
Jason Laughon
10-28-2007 05:08:19
Do you have any pictures?
Don Hooks
10-27-2007 18:53:14
Matt,
Where are you located? Do you have pics? As for ford and Ferguson: without Harry Henry wouldn't have sold a ford worth having.
