TO-30 3 Point Lift Pins
glenmorebuckman
10-26-2007 15:16:46
I'm wanting to replace the three pins on the back of my tractor at the hydraulic lift spring for there are just bolts of all sizes in there now. Does anybody know what type and size pins I need? I have one for the top link end so I just need to know about the other two, the one that goes through the rocker and lift spring and the long one below that. Also, what is the longer pin below the rocker used for?Thanks, Billy
glenmorebuckman
10-28-2007 19:43:35
 Re: TO-30 3 Point Lift Pins in reply to glenmorebuckman, 10-26-2007 15:16:46
How long is the hinged pin? I can't find it on the web.
John(UK)
10-27-2007 07:29:42
The pin through the yoke end on the Draft Spring is 3/4" dia x 3.14" long. The hinged pin is a special as it has a "collar" built in on the left side, these are available from Sparex dealers under part number S00070, it may also be available from this site(YTMAG) also. To find the name of your nearest Sparex dealer, email [email protected] The lower link pins are 7/8" dia on Cat 1 linkage. The long hinged pin is used for a variety of purposes, among them, to attach the drawbar, attach a Pick-up hitch, it is used for locking some implements at the correct height when the PTO is attached, it also supports the Bush through the Rocker for the Top Link.
