Injection pump timing 23c standard diesel
matt jones
02-26-2001 08:59:51
I&t manual states crank engine until #1 piston is coming up on compression stroke, then insert rod into timing hole. My question is how can i tell when the #1 piston is coming up on compression stroke. Head is on engine and valve cover.
Jerry in Id
02-26-2001 21:49:47
 Re: injection pump timing 23c standard diesel in reply to matt jones, 02-26-2001 08:59:51
Matt. On your injector pump there is a inspection plate that is secured by two bolts {5/16 head}. Remove this. Inside there is a shft that is driven by the camshaft gears. This shaft has some alpha letters on it. The one you are interested is the letter "G". Crank your engine until the scribe line that is associated with the "G" and the scribe line on the ring are matched. When this happens, number one cyl. will be at 19 degrees BTDC and yor 1/4" rod should slip through the hole in the flywheel. Be sure and turn off your fuel supply and put a pan below your injector pump before you do this. Keeps your shop floor clean. Hope this helps.
Jerry in Id
02-27-2001 10:11:18
 Re: Re: injection pump timing 23c standard diesel in reply to Jerry in Id, 02-26-2001 21:49:47
Matt. I did not have my I&T manual with me last night, but the para # is 138 in my manual. The manual # is MF14, no date, and is on page 46. Interesting, I just took my pump off and will be taking it in for "refurbishing" tomorrow. I could not find any instructions on the tear down or inspection of this pump so I am taking it to a injector pump shop. They sure are expensive. Good luck on your installation. By the way, I would think that you should align the scribe marks on your pump, look to see where the key is on the drivi gear, crank the engine until the corresponding key is in the same Clock position at which time you should be able to manually turn the engine over to fine tune the rod insertion. Let us know how things work out.
Jerry in Id
02-27-2001 10:08:30
Jerry in Id
02-27-2001 10:05:25
matt jones
02-27-2001 07:19:08
Jerry thanks for your reply the pump is off i just did a complete refurb and trying to get it back toghter and fire her off.
peterc
02-26-2001 18:59:39
pull the valve cover off it only takes a little time.
matt jones
02-27-2001 07:17:14
 Re: Re: injection pump timing 23c standard diesel in reply to peterc, 02-26-2001 18:59:39
when the valve cover is off how can i tell #1 cylinder is on compression stroke thanks.
