PTO Override question
John H TO20
10-22-2007 14:38:56
My TO20 has a PTO override clutch on it. Does that need to be removed to replace the PTO shaft seal? If so how is it removed? I haven't figured out how to get it off if I need to.
Thanks,
John
John H TO20
10-23-2007 06:13:24
 Re: PTO Override question in reply to John H TO20, 10-22-2007 14:38:56
Thanks for all of the replies. I plan to replace the seal. From another thread I got the impression that was a pretty straight forward job. But, it's always good to know what to expect. I'll try to pull it out this weekend.
phil(va)
10-23-2007 04:41:27
Like the others said. However, if you can get to the bolts holding the shaft, you might leave it on until you get the shaft out. You might need the extra length to help you pull the shaft out, if it's balky. Some resist a little bit, others slide right out.
john[mo]
10-22-2007 15:41:14
to remove it just take out the two grease fittings. you will then be able to drive the roll pin out through the grease fitting holes.
marlowe
10-22-2007 18:26:26
 Re: PTO Override question in reply to john[mo], 10-22-2007 15:41:14
but you will have to hunt for the pin because it's not in line with the zerks
