Oil Pressure and Temp Gauges for TO-20
Fred
02-25-2001 15:44:26
I have a 1950 TO-20 that does not have an oil pressure gauge or a temperature gauge. I've seen other TO-20 owners referring to these gauges on their tractors. Can they be added and if so where are they connected to the engine?
Neal(IN)
02-26-2001 03:20:25
 Re: Oil Pressure and Temp Gauges for TO-20 in reply to Fred, 02-25-2001 15:44:26
Fred
If you look at the neck where the top radiator hose connects to the engine there should be a plug on the left side. This is where the water temp is hooked in. TISCO makes a gauge that will fit that opening.
Neal
Fred
02-26-2001 11:27:05
 Re: Re: Oil Pressure and Temp Gauges for TO-20 in reply to Neal(IN), 02-26-2001 03:20:25
Found the plug exactly as you described. Thanks for the info. Now I'll have to find out where to order the gauge.
Bill Mc
02-25-2001 18:54:27
third party image
This is a pic of my TO-20 oil pressure connection fitting (center of pic brass street elbo).It is on the right side behind the carb.
Bill Mc
Fred
02-26-2001 11:28:12
 Re: Re: Oil Pressure and Temp Gauges for TO-20 in reply to Bill Mc, 02-25-2001 18:54:27
Found the plug exactly where you said it would be. The picture was a big help too. Thanks again.
Badapple
02-27-2001 18:13:38
 Re: Re: Re: Oil Pressure and Temp Gauges for TO-20 in reply to Fred, 02-26-2001 11:28:12
Another guage to have is a TACHOMETER. I hooked up an old Tach/Dwell meter to my TO-20
and read the 8 cylinder scale x 2. It comes in handy while spinning a mower or running down the road. I hung it on the dashboard @10 years ago and although it isn't perfect it sure is handy.
