pressure guage
h. david
10-19-2007 15:59:07
any ideas out there where to come across a pressure guage fo testing pump pressure on a 1950 to 20, manual says 2300. still having troubles with a weak and sometimes no rear lift. have replaced control valve, relief valve, not found any leaks. found the control fork stress cracked and replaced that also. will check pressure as a last resort before pulling the pump and overhauling it. also replaced the spring from fork to ram.
DennisPinOhio
10-24-2007 04:15:13
 Re: pressure guage in reply to h. david, 10-19-2007 15:59:07
I bought one last year for my TE 20 at the local NAPA store. It was not at all expensive.
Jerry/MT
10-19-2007 16:26:24
Northern Tools has pressure gauges that go up to 10,000 psi last time I looked. If you get one, get a glycerin filled one so that the high frequency needle oscillations are damped out somewhat.
I think you"ll need to get a 5000 psi guage since you wnat to measure near 2500 psi. The gauges, as I recall( but don"t hold me to it) go like 3000, 5000 and 10,000. Since you can get some momentary spikes in the pressure as valves open and close and pistons stop, I would recommend the 5000 psi gauge.
Regarding your lift problem,sometimes the piston can bind in the cylinder. Another place that can leak is the "riser" tube that is in the upper right hand corner of the hydraulic compartment where it goes into the lift cover. It"s hard to see unless you look from the left hand side access cover. It sounds like you have been very thorough on trying to solve this problem and have replaced the things that you can without dropping the pump. According to the trouble shooting guide in the Ferguson Service Education Manual I have, the side plate valves may also be binding due to varnish and corrosion.
John(UK) , a regular poster, has a real good knowledge of this system and he may be able to provide more help than I. You might holler for him in a separate post.
