need help with safety switch
DennisPinOhio
10-15-2007 05:36:00
I"m going to rewire my TE 20 so I can use the gearshift starter, i.e., the "S" position.
To save me some work, perhaps someone can tell me which terminal on the switch gets the hot lead from the battery. Tractor is 12 volt, negative ground.
Thanks in advance.
Dennis
Jerry/MT
10-15-2007 10:36:54
 Re: need help with safety switch in reply to DennisPinOhio, 10-15-2007 05:36:00
The terminal doesn"t make any difference because it"s just a open-close switch supplying the starter current. Generally speaking, it"s easier to put the hot lead from the battery on the right side terminal and the cable to the starter on the left side trminal. The switch has some fore and aft adjustment and as I recall when I replaced mine, moving it aft was where ine needed to be to get full contact.
Jeff-oh
10-15-2007 05:53:49
third party image
Dennis,
I just took my terminal apart the other week. Here is a picture or the innards of the switch. As you can see the two copper terminals have a D-shape head. The push button is connected to the copper disk. Thus when the disk connects the two D head terminals the connection is made.
Does not matter which terminal is which.
I also have a picture of the switch as I am pullung it out. Let me know if you want that posted.
Jeff
DennisPinOhio
10-16-2007 06:06:15
 Re: need help with safety switch in reply to Jeff-oh, 10-15-2007 05:53:49
Yes, Jeff please post that picture.
Thanks.
john[mo]
10-15-2007 05:43:22
it does not matter which terminal is used for the battery cable. i think it is usually the closet to the dashboard for the battery cable.
DennisPinOhio
10-16-2007 05:57:45
 Re: need help with safety switch in reply to john[mo], 10-15-2007 05:43:22
WOW! Three responses. I really appreciate it, guys.
Thanks to all.
