to 25
ford-s
10-13-2007 16:24:59
guys i have the chance to buy a '50,or '51 ferguson,and it is supposed to be a TO 25.now i have seen TO20's,30,35,and 65,but never a 25,my question is did they make a to 25?thanks,cw
ford-s
11-23-2007 06:52:15
 Re: to 25 in reply to ford-s, 10-13-2007 16:24:59
gentlmen,I bought the tractor,the serial nos.showed it was a 1950 to-20,thanks for the help,now I can join'the fergie family'.
Bob (Aust)
10-16-2007 03:06:48
Jeff.
I don't think the TO20 ("Tractor Overseas") was ever built in the UK.
The Z120 Continental engine TE20 ("Tractor England") was built in the UK.
The "-85" was attached to the Standard Engine TEA20 when the engine was upgraded from 80 mm bore (23.9 HP) to 85 mm bore (28.2 HP) from Ser No 172599 in 1947.
Jeff-oh
10-15-2007 07:08:10
Most likely it is a TO-20 or TO-30. It is possible it is an english built TO 20-85.
Look at the left side of the engine. If gas note any number near the oil pan i.e. Z120, Z129 etc.
Also look to see if it has an external oil filter. If so let us know where it is.
ford-s
10-13-2007 18:14:31
thanks for the info,i will be running a serial no.down when i get it home.i am new with the 'fergies',my expertise has always been ford,and fordsons.so i am sure i will be calling on you guys alot,thanks again,cw
steveormary
10-13-2007 18:07:38
MF 25 diesel. built 1963 built in France
24.4 pto hp/20.6 db hp. @ 2000 rpm
107 ci 4 cyl. Perkins diesel 8 fwd gears 1.1-14.1 mph
wt.3115#'s
Rob in OH
10-13-2007 17:43:45
ford-s They did make a MF25 it was a French built Massey Ferguson. A few of them made it to the US. I don't know the years of production, but I would guess the first ones were made around 1960. They were all Diesels and they were rather small in size. Maybe this will help you ID the one your looking at. There was no TO25 made.
Duner Wi
10-13-2007 16:43:55
Do you suppose it could be serial #25??
Not impossible.
