TO or TE
Please Help
02-22-2001 16:35:13
My tractor has To 7006 on the transmission and TO 4024 under the seat. My serial no. is not readable. Am I correct that this is a TO 20. The plate on my engine has serial no. 153950 I believe this to be a TE 20 serial no?
Wayne
02-25-2001 20:42:42
 Re: TO or TE in reply to Please Help, 02-22-2001 16:35:13
TE, for Tractor England uses an aluminum trans cover. TO, for Tractor Overseas uses a stamped steel trans cover. Do you know why the English drink warm beer? Because they have Lucas refrigerators.
Tom B
02-23-2001 15:05:26
On the TE's, the transmission cover and steering housing is one piece. The TO has a separate transmission housing cover where the gear shift is located.
Tom B
Topeka Ks
Tom B
02-23-2001 15:03:20
Tom B
Topeka Ks
Tex Ferguson
02-22-2001 18:22:18
You came to the right msg board to find out all about Fergusons! My '49 TE-20 has Lucas generator and starter, but someone replaced the Lucas distributor with the corresponding Delco unit found on TO-20's. TO-20's had all Delco electrical parts. I haven't looked mine over carefully enough to discover the #'s you describe on trans and under seat. Have fun with it! Tex
Tex Ferguson
02-22-2001 18:19:14
wes mo.
02-22-2001 18:16:25
if it has a lucas dist.or gen it a Te,if delco To.
