To-30 Year
glenmorebuckman
10-08-2007 20:01:01
The serial number on my tractor is missing, but on the engine block there is a tag that says z129 e300881. Can I find out the year of manufacture by using this tag?
glenmorebuckman
10-09-2007 18:27:41
 Re: To-30 Year in reply to glenmorebuckman, 10-08-2007 20:01:01
Thanks for all the help guys! I sure appreciate it.
John (UK)
10-09-2007 08:58:07
There should also be a date cast into the front of the Rear Axle trumpet housings, immediately behind the brake shaft/
Jeff-oh
10-09-2007 07:48:05
Glen
This is the best that can be done with out the actual SN. FYI
Jim in OH
10-08-2007 20:39:06
third party image
300881-240000=60881 approximate serial number.. a very early 1951... nominally 800th to 1000th off the line.... Jim
glenmorebuckman
10-08-2007 20:20:28
Yes, I found the plate under the steering wheel but the number has been mysteriously removed
Jerry/MT
10-08-2007 20:09:12
Jim in OH has published a list of engine numbers as a function of model year. Look in the archives and see if you can find it. Have you found the tractor serial number on the plate beneath the steering wheel with a number like TO ABCDE? If you have that ytou can find it in the Serial Numbers under Research & Info on the left on this page.
