TE20 Starting Problem
Zorro1
10-07-2007 19:36:43
Hello, I have a TE20 that has been siting for 6 months. I charged up the battery and tried to start it. When I turn the ignition key, nothing happens (only a small spark where the battery cable connects to the battery) It appears that something is shorting. I have a 12 volt system with a resistor block. Does anybody have any ideas as to what my problem may be? Thanks, Zorro
Gene Stevens
10-08-2007 17:46:12
 Re: TE20 Starting Problem in reply to Zorro1, 10-07-2007 19:36:43
Actually...you are as smart as us! You asked the question. The only dumb question is one that was not asked. So all questions must be smart.
John (UK)
10-08-2007 12:24:44
Clean and tighten the battery terminals and cables, both where they fit the the battery posts and where the cable fits into the terminal. It is just a bad connection....John
Bob (Aust)
10-08-2007 04:50:23
If you have "a small spark where the battery cable connects to the battery" for sure you have a loose battery connection, which certainly won't help!
Zorro1
10-08-2007 15:14:17
 Re: TE20 Starting Problem in reply to Bob (Aust), 10-08-2007 04:50:23
It worked!! I cleaned the connections and it fired right up after sitting for so long. Thanks for your help. I wish I were as smart as you'all. Thanks again, Zorro Casanova, VA
