TO-30 Radius Rod Question
Ron Lindquist
10-07-2007 19:32:21
Was going to install a Pawl Sector that I got on eBay, Parts book says TO-20 & To-30 are the same. There not, mounting holes are bigger on TO-30. Anyway had to disconnect Radius Rod to put in Pawl, there was upward tension when I took bolts out. Now putting it back together without Pawl but Radius Rod ball is about 4 inches above socket. I can fource it in but wondering if I should, and what the problem might be. Rod does not seem to be bent. Any Ideas ??? Thanks, Ron
John (UK)
10-08-2007 12:22:00
 Re: TO-30 Radius Rod Question in reply to Ron Lindquist, 10-07-2007 19:32:21
Hi Ron, Yes you can press the Radius Rod down until it matches the socket in the footrest. The reason the Radius Rod does not match up is that there is wear in the front axle pin and allowing the axle to tilt.....John
Jeff-oh
10-08-2007 06:19:38
What happens if you rotate the radius arm 180 degrees? I am not sure it there is a top and bottom to these.
Hills Of TN
10-08-2007 06:12:09
I had the same problem when I "reconditioned" my TO20. The holes in the front axle and the axle support assembly had worn enough that the pivot pin allowed the axle to tilt forward, putting down pressure on the radius rods. My radius rods were bent because of the pressure.
