TE 20 Ferguson
Lyle Harvey
10-07-2007 08:52:39
I just bought this tractor and when I removed the head, I found two cracks in the block. One was between the #1 and #2 cylinder and the 2nd between the #2 and #3 cylinder. I would like to think tha that the new head gasket will prevent these two cracks from being a problem but am I kidding myself? Is this a fatal blow to my engine?
Jeff-oh
10-09-2007 07:52:40
 Re: TE 20 Ferguson in reply to Lyle Harvey, 10-07-2007 08:52:39
As Jerry said, Head cracks can occur, Not the end. Many cand be weld repaired. Look up a real auto shop and ask.
Jerry/MT
10-07-2007 13:38:54
This is common with Continental engines when overheated. Normally, these cracks usually don"t cause a problem. My original TO-30 had the same cracks you described and I never had a coolant leak problem. If the cracks propagate downward toward where the cylinder lines sit in their o ring seals, then you are likely to have a problem.
Here"s my advise for whatever it"s worth. Check your oil on a regular basis looking for signs of coolant in the crankase oil. Worry about those cracks when you see coolant in the crankcase.
Then you can get a furnace braze block repair and be back in business.
Lyle Harvey
10-08-2007 05:27:37
 Re: TE 20 Ferguson in reply to Jerry/MT, 10-07-2007 13:38:54
Thank you for your reply. I will probably put it back together and try it. Thanks again.
