Steering arm seals
Fred Caldwell
02-21-2001 04:23:06
Can anyone offer some advice on how to go about replacing the steering arm seals on a TO-20? Do you have to completely disassemble the steering gear box and remove the arms? It doesn't look like the new seals will slide up over the arm to allow thme to be installed from the outside.
I've got all the "leaks and drips" fixed except this and would appreciate any help you can offer.
Neal(IN)
02-21-2001 07:02:45
 Re: Steering arm seals in reply to Fred Caldwell, 02-21-2001 04:23:06
Fred
Sorry to be the bearer of bad news but yes you have to disassemble the box to replace the seals.
The good news is that it really isn't to difficult just time consuming. If you are going to go that far check the bushing's and bearings. I couldn't find a source for the outer bushings so I put it back together with the old ones. It doesn't leak but has a little more slop than I would like. One word of warning. When you adjust the clearance on the sector gears (using the big screws near the top of the curved portion of the steering box) be sure to check them through the full range of motion. I read some where that if you adjust them with the steering centered (which is where most of the wear is) then turn the wheel all the way to the left or right, you can generate enough side force to crack the housing. Mine ended up being tight at the extremes and a little loose in the center.
Neal
Fred Caldwell
02-21-2001 15:29:19
 Re: Re: Steering arm seals in reply to Neal(IN), 02-21-2001 07:02:45
Thanks for the Information. I'm not totally surprised but guess I was hoping that there was an "easy" way to replace them. But, they're really leaking alot and I want to fix them before I repaint. We'll see how it goes.
