to30
delane hawkins
10-03-2007 19:29:05
i instaled a new distributer on my to30. it has a z129 continental 4 cylinder engine. i am not sure on the firing order on the distributer cap. the cap has a number 1 on it for the number 1 spark plug wire. could someone give me the firing order for the rest of the plug wires. any help would be appreciated.
mark from the fort
10-04-2007 06:54:18
 Re: to30 in reply to delane hawkins, 10-03-2007 19:29:05
1,3,4,2
Pretty sure as you look at dist.
top left goes to #1 cyl.
top right #2
bottom left #3
bottom right #4
-assuming your dist. is timed where #1 is in this position.
Mark
Jeff-oh
10-04-2007 06:37:52
As said 1-3-4-2 is the firing order. Also make sure you have the timing set and are on the compression stroke.
greenbank
10-03-2007 21:10:56
1-3-4-2. On my Z134, it's cast into the engine block just above the distributor, not sure if it is on a Z129.
Counter-clockwise.
