TEA20 Lube Specs
Darren Patrick
09-29-2007 16:45:17
Hi, can anyone tell me what oils I need to use in the transmission and rearend and where to check and add the fluids? Thanks
Jeff-oh
10-01-2007 07:30:37
 Re: TEA20 Lube Specs in reply to Darren Patrick, 09-29-2007 16:45:17
The rearend takes 6 gallons of GL1 gear oil. This is available in the States fron NAPA stores and is PN 65-205 for the 5 gallon jug.
You fill it through the plug that is near the shift lever. Be careful as you get near the end of filling as it takes a few minutes for the lube to level out with the dip stick at the rear and it is easy to over fill.
There is a rear end fluid changine procedure available if you want it let me know.
Jeff
Darren Patrick
10-02-2007 12:44:55
 Re: TEA20 Lube Specs in reply to Jeff-oh, 10-01-2007 07:30:37
Thanks Jeff, What about the transmission. Does it take a different oil?
