TE20 Brakes
CPD Sarge
09-27-2007 10:18:44
Can anyone help the old Sarge? I need a pair of centralizer bolts for the brakes. Went to adjust them after finally getting the tractor running and it snapped off way too easy! The part number is 825-550-M1. I can't find a dealer that carries this part. It's not a standard 3/8-24 bolt as it has a shoulder with a flat cut on opposite sides. If you have a couple extra ones lying around or know of a parts dealer that has a couple I would sure appreciate the info. Thanks!
John (UK)
09-28-2007 10:15:34
 Re: TE20 Brakes in reply to CPD Sarge, 09-27-2007 10:18:44
If you can't get the proper one you can use an ordinary bolt. To get round the problem of it not having the shoulder so as to allow some movement to align itself, use a nyloc nut on the bolt and you can then tighten it, but not quite fully and it will be able to move sufficiently. Either that or make a new bolt.?....John
Andy D.
09-27-2007 10:37:17
I checked in the parts section of this website and could not find the part in question so I dont feel too bad about steering you to a different site. Go to sparex.com You'll have to contact them to find a distributor.
Jeff-oh
09-27-2007 14:06:14
 Re: TE20 Brakes in reply to Andy D., 09-27-2007 10:37:17
Sparex may not have this I checked their catalog, do you know differently?
Andy D.
09-27-2007 14:52:05
 Re: TE20 Brakes in reply to Jeff-oh, 09-27-2007 14:06:14
Oops, I guess I shoulda checked sparex before I said to go there. You're right, I don't see the centralizer.
